Best Wireless PCI-e Card for Gaming/Web Surfing?
gpickett
16
I recently built a gaming rig and now I am in need of a wireless pci-e card. Ethernet is no option. I will primarily be using my University's WiFi connection, if that has anything to do with the card choice.
Thank you for your input.
I use n adapters ranging in speed from 150-300Mbps and all keep up with gaming, example http://www.newegg.com/Product/Product.aspx?Item=N82E16833166073&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-na-_-na-_-na&cm_sp=&AID=10446076&PID=3938566&SID=
Intel based solution is normally best, all the Killer NIC's have been popular due to the way they can be customised.
up to 300/867mbps 802.11AC connection
Intel 7260HMWDTX1 PCIe x1 Dual Band Wireless-AC 7260 for Desktop
up to 600/1300Mbps connection
ASUS PCE-AC68 PCI Express Dual-band Wireless-AC1900 Adapter
Snookslayer
231
I noticed all of your suggestions consist of PCI-e cards. Would there be any noticable difference using just a regular PCI card like this...
http:// ???
Some of us have crappy old mobo's with limited PCI-e slots. I know PCI technology is a dinosaur, but as far as internal WIFI cards, does it makes a difference?
It will work fine, no difference really. PCIe is recommended today since many boards have gotten rid of the PCI slots.
Snookslayer
231
Thanks. Now that I'm looking, you're right that many of the $175+ mobo's don't have those old PCI slots, but they still keep putting them in the $100+- mobo's. I guess they'll probably be completely gone eventually.
On a side note, I've noticed even in the most expensive mobo's today, they still keep putting those ridiculous multicolored round inputs for old keyboards and mouse's from the 1980's. I find it hard to believe anyone looking to buy a modern $200 mobo and is still using those old keyboards and mice.?. Crazy. : )
