Better monitor?
arcticle
Guest
Jul 29, 2012
114
So I plan on getting a GTX 670, and am planning on buying a 1080p 24" monitor. Yes, this is overkill, but I want to future proof my graphics card, especially since the XBox 720 and PS4 are just around the corner. Now my question is, can I (and should I) get a better monitor (same size, greater resolution)? I do not want to spend more than $200.
Would I notice a gaming improvement using a monitor with a resolution >1080p? Would I even notice the difference?
Thanks!
