Better to use 1 4GB stick or 2 2GB stick
tipd
14
I'm looking for new ram an i found that a single 4GB stick is cheaper than 2 2GB sticks. is there any performance difference between the two? or any other reason why 2 2GB sticks would be best.
(I have 4 RAM slots so space for more ran isn't a worry)
For optimal performance, as already stated above, always, always install memory in identical pairs! A single stick of memory will not run in dual channel mode and can cost you 3-7% performance.
Like the guy above me said, having 2x2 will make it slightly faster since they will run in dual-channel, its probably like a 10€ from 4gb to 2x2 (i estimate) so only get the 4gb ram if you plan on buying another one)in the near future), and maximazing your value :)
