Between ABS and Asus
Andre_17
7
i wanted to know if ABS is reliable because if i choose to buy a prebuilt desktop i'll choose between these 2:
http://www.amazon.com/G11CD-US006T-Gaming-Desktop-Nvidia-GTX980/dp/B016E80LF0/ref=sr_1_1?ie=UTF8&qid=1447875528&sr=8-1&keywords=asus+g11cd
or
http://www.newegg.com/Product/Product.aspx?Item=N82E16883102075
on the one hand the asus is 500$ more expensive but it is an Asus...and i get x2 RAM ,DDR4 , on the other hand the ABS is much cheaper and i get a gaming keyboard and mouse
what do you guys think?
I'd probably go with the ABS. It's only big down side is that it's CPU is 2 generations old. But CPU's don't tend to age as badly as the GPU. Personally I'm still running a i7 2700k and can't find a good reason to upgrade. The 500 saved could go toward a nice ultrawide monitor.
As for the ASUS, it is worth the extra 500 considering it has all the latest parts. But if that means you can't have a nice monitor, keyboard and mouse then it's not worth it.
