BF4 HELP error: something went wrong
halla654
18
Yesterday bf4 and bf3 played just fine, but today bf4 just quits while in server loading screen, either with no error message or with an error message that says: "game disconnected: something went wrong". But with bf3 it just quits with NO error message.
running chrome and windows 8.1.
please help me, im sooo frustrated!!
- halla654
Try installing the latest drivers for your video card!
with reinstalled punkbuster i get this error: "Game disconnected: Client closed down connection. Check your network connection and make sure that port 3659 (UDP) is open."
evga gtx770 driver: geforce 337.88
I have enough ram, but how do i enablr my pagefile. I get these error messages: something went wrong. Disconnected from EA (1). Port UDP 3659. Server time expired
i already tried the port thing, it didnt work. one thing to note is that bf3 doesnt work either, same thing. i've found out that my brother was on my pc before all this happened and there is something that he may have done that changed something about my internet (note, he is not very smart so he couldnt have done anything too soffisticated). i also found out that in battlelog i get really bad pings and neither arma 3 or dayz servers works now, so there has to be something about my firewall or notwork or something. i have no clue on watts going on?!?!
If you're using a router you're protected by a NAT firewall.
I'm assuming you have the windows firewall activated as well.
Try connecting directly to the modem without the router and disabling any firewalls and see if that helps.
What browser are you using?
If you're using Internet explorer - can try disabling it by removing it from programs and use Google chrome as your default.
its weird, cause my brother couldnt have accessed and made changes to something like that. and i have a multimodem. i asked what he had done, and he said: "i logged on to your pc and clicked on the bf4 icon on your desktop and when i tried to log on a server it didnt work, so i played some campiagn instead". is it a notification he might have pressed on or something. i have nothing weird installed on my pc.
Looks like it's a browser problem however trouble shooting will need to be done because I'm not sure.
I suggest you try removing your default browser and using another browser as your default.
Although not completely necessary I would also delete Bf3 & bf4 and reinstall everything from the beginning.
There should be a way to disable router functionality from the modem however you can try this if all else fails.
You can also try putting your local ip address in the DMZ./
i think all this has something to do with my antivirus program norton 360, but i havent found out what might have changed YET. any ideas?
nope. i get the same errors. now im really frustrated!?!?
i have tried that. it didnt change anything, and no-one has changed anything about the ports anyway.
I suggest you reinstall the games and change your default browser.
I think there is a possibility the steps above will solve your problems.
When I have problems with games the steps above are part of my trouble shooting procedures if I don't solve the problem with in a short time because sometimes finding the exact problem is like finding a needle in a haystack and is time consuming.
Reinstalling the game sometimes fixes the problems.
As you know there was a update recently and it's possible that something went wrong in the update process.
