bf4 lag please help
deano1671
56
hi i have a i7 4770 cpu G1 sniper z87 mb, haswell, os on ssd, bf4 on another ssd, gtx 770 sli, nzxt cooler for cpu, evga g2 850w psu and corsair 760t case with 9 140mm sp corsair fans, im getting 200fps constant but still feels laggy, or and 16gb ram at 18,888mhz
Monitor refreshing not in sync with frames rendered I think. When you enable V-Sync it should be butter smooth.
Or if you don't want to use V-syinc try typing ''Gametime.Maxvariablefps 60'' in BF4 command, or whatever your monitor refresh rate is. So if it is 144 you use that number instead of 60.
