G guapotims Commendable Jan 16, 2017 4 0 1,510 Jan 16, 2017 #1 Has anyone connected their speakers up Bi-Wired? Does it make a difference in power to the speakers? Better sound? Worth doing?
Solution Reynod Jan 17, 2017 Short answer ... unless you have top notch gear then you probably won't notice any difference. I tried this years ago. Do use oxygen free monster speaker cable though ... that will definitely improve your speaker response.
Reynod Administrator Mar 26, 2007 14,921 16 42,215 Jan 17, 2017 Solution #2 Short answer ... unless you have top notch gear then you probably won't notice any difference. I tried this years ago. Do use oxygen free monster speaker cable though ... that will definitely improve your speaker response. Upvote 0 Downvote Solution
