Im not tech pro so i dont know psu but my pc turn on without problemWhat is full system spec including PSU make and model?
The might be a short or the PSU might be failing. I wouldn't turn the PC on with that PSU unless you have it tested and it's OK.
I would check the case grounding.My pc has worked fine past few year's but since yesterday it gives lots of electrical shock...when i put my Arduino board or usb it shocks me and turn of breaker .
And also audio out connected to subwoofer that wire also shocks me..Why..
