Archived from groups: alt.comp.periphs.mainboard.asus (
More info?)
"Chris Gibbins" <newsgroups@losimagic.net> wrote in message news:<1084721763.27866.0@nnrp-t71-02.news.uk.clara.net>...
> "Duncan M" <duncan_mclean@yahoo.com> wrote in message
> news:9e0d239b.0405150706.5dc91716@posting.google.com...
> > "n" <neal206@hotmail.com> wrote in message
> news:<Cqipc.2325$YS4.19@doctor.cableinet.net>...
> > > news:9e0d239b.0405140507.3f1fd393@posting.google.com...
> news:<1084349547.58032.0@doris.uk.clara.net>...
> > > > > Got this today, installed it fine.
> > > > > Now I am trying to get my laptop (Acer Travelmate 803LmiB Centrino)
> to
> > > > > connect to the internet via the Wifi-b but it's not working
> > > > > The laptop can see the connection and is connected to it, but I
> can't
> ping
> > > > > this system (on which the wifi-b is installed) and I can't ping the
> laptop
> > > > > from this system - and I can't get online using the laptop either
> > > > > Both systems are running windows XP pro, and the mobo the wifi-b is
> > > > > installed on is the P4C800-E
> > > > > I've got ICS setup, I've run the wizard several times but still no
> joy
> > > > > I've tried to connect both with and without a firewall (norton) and
> I've
> > > > > disabled the windows XP firewall on the internet connection
> > > > > Any ideas?
> > > > > Thanks
> > > > Hi
> > > > Does anyone have an answer for this...I am beginning to pull my hair
> > > > out!
> > > > I am having exactly the same problem, but as a client connecting to
> > > > Win XP pro I am using an apple ibook laptop (actually trying to set up
> > > > my partner's) so
> > > > she can share broadband access.
> > > > The apple (using an Airport Extreme card) finds and connects to the
> > > > wireless network fine. However, I cannot ping the XP machine...as the
> > > > guy above is finding.
> > > > Pretty sure the problem lies in the XP side of things, but cannot for
> > > > the life of me see what.
> > > > Help would really be appreciated on this.
> > > > Thanks in advance
> > > > Duncan
> > > Sounds like it may be firewall related. Go into the lan settings
> properties
> > > and look at the advanced settings tab. Try turning off the built-in
> winxp
> > > internet connection firewall, and see if you can then ping.
> > > If you have another firewall product installed, you may have to
> > > figure out how to do the same thing.
> > > Good luck.
> > Hi
> > Thanks for this, but I made sure that XP's firewall was not turned on
> > on the Internet connection and I did have an alternate Firewall
> > running (Norton) but disabled that. Still no joy whatsoever.
> > Anything else it could be?
> > Cheers
> > Duncan
> Uninstall the software that came with the wifi-b - let windows handle the
> card, it worked for me then
Hi Chris
Forgive me for being a bit stupid, but I seem to be having problems
doing just that.
I have uninstalled the software, then tried to create a new network.
But when it comes down to it my Wireless Network connection has a big
X through it.
Can you tell me the exact steps you took to get this thing to work
(I'm obviously pretty new to this wireless game!)
Thanks again.
Duncan
