big ptoblem with battery
Esloch
Hi,
I have a big problem to power supply of my laptop,
I would like to solve this problem power my PC using the power plug of the battery, but without using the battery, defective it too
Can I directly connect a power supply to the battery plug? and how ?
need help 🙁
Thanks
Finally I success to replace my PC battery by a 12V power supply (with some slight modifications), the PC works, it believes that there is a power supply via battery but that there is a problem with this battery, you have to eschewe the alert message ...
possible
