[SOLVED] BIOS And Ai suite 3 Not Recognizing All Of My Fans
That case uses 6pin proprietary fans that go to a controller on the back of the motherboard tray. It's a lighting controller that'll handle motherboard sync or through the case rgb switch, but as to fan control,
Removing the front panel will show the two 200mm ARGB fans. The user can’t control the speed of these fans due to a proprietary connector being used (6-pin)
And your fans on the rad are plugged into where exactly? They should either be plugged into cpu_fan header or the pump or a sys_fan header.
In cpu_fan or sys_fan header they should be recognised. In the pump they get recognised by software via USB cable.
