Ok so I am new to overclocking, but done alot of reading. I have started overclocking just a couple days ago. I have had this system for 2 years and its been rock solid.
Heres my setup
Ga p35 DS3r Rev F2
Q6600 G0 Stepping SLACR w Zalman 9700 attached properly w as5
2x2gb Corsair DHX DDR2 1.8v 5-5-5-18 (I can't tweak the timings with this bios)
GTX 260 w 216 (just upgraded a couple weeks ago)
Corsair 550w PSU which seems more than adequate
320 gb seagate 7200rpm sata
Antec 900 with plenty of fans and airflow
Vista ultimate 64 bit
So after reading dozens of threads I set my FSB to 333, set ram timings to 2:4 (to maintain the 800 mhz ratio) and put my PCIe on 100 CPU voltage at 1.262v. Here is my issue = My computer boots at 332 FSB not 333... I can't figure out why. If I put it on 334 it boots at 334 which seems fine but it throws my ram timings of to something goofy like 5-6-6-18
Another thing is that CPU-Z shows my voltage much lower than what I set it at and it fluctuates. Core temp says 1.30VID no matter what I do..
Now that said I ran prime 95 and it did stop with an error and I upped the CPU voltage to 1.275 to see if that will help.
I did actually set the FSB to 400 with voltage at 1.35 and it started but wouldn't boot windows. I'm sure I need to add voltage to the mobo but not sure how much and kinda didn't want to go there. Any recommendations?
I didn't want to throttle my machine too hard, because I do use it for work, and don't want to burn it up. But I had to admit overclocking to 3ghz made a big difference in my games (esp COD & Crysis).
On the bright side with prime 95 large FFT I can't force my cpu over 57c @ 3 ghz after two hours (2.988 actually because the stupid FSB issue), which seems pretty comfortable. I think I got a CPU from a pretty good batch.
All that said my main questions;
Do I need to update bios to fix my FSB issue, or maybe just try clearing cmos first?
What is the danger of a machine that seems stable but won't clear 24 hour prime95?
And other random questions;
How safe would it be to go 400 on FSB, what other voltages should I adjust, and what mobo temperatures would be safe? Or should I just stick with 3ghz since its my work machine? I want this comp to last another 5 years..
Maybe I should aim for like 380 fsb or something? I am eager to suggestions on ratios.
My ram has huge heatsinks on it, should I try to OC it a little (I mean leave the 1:1 ratio with upped FSB) if so will a little extra voltage hurt it?
Once again I don't mind playing with fire, but stability is my first concern.
Thanks for the input. I'm a long time reader and a first time poster.
Heres my setup
Ga p35 DS3r Rev F2
