Hello, I am following the "November System Builder $650 Gaming PC"
Using the same components as in the artical:
CPU Intel Pentium E5200 2.5 GHz,
Motherboard Gigabyte GA-EP45-DS3L,
RAM PNY XLR8 4GB (2 x 2 GB) DDR2-800 (PC2 6400) ,
Graphics Sapphire 100245L Radeon HD 4850 512 MB,
I am new to overclocking and having some problems.
I am able to adjust the clock ratio (downward, default of 12.5 is the highest it goes)in the BIOS or using EasyTune 6. But, when I try to adjust the bus speed with either EasyTune 6 or the BIOS it never seems to save it. Every time I check CPU-Z it says the bus is still at 200 MHz.
I have updated the BIOS and it still will not change the FSB.
I changed the multipler from the defualt 12.5 to 11 and the FSB from 200 to 333 and the vcore to 1.3 as in the system builder article. I also tried changing the multipler from 12.5 to 11.0 with the bus from 200 to 266.
Neither works!
After savinging the changes (f10) the system self reboots 3-4 times and loads the bios settings back to the original.
What else do I need to Change?
Is there more BIOS setting information for the "November System Builder $650 Gaming PC" on the site somewhere?
Any help would be greatly appreciated.
Thanks
Neither works!
Thanks
