Okay, i have a quad monitor set up. All of the monitors are hooked up to a single graphics card and all will work at the same time. I have 3 monitors set up on an arm on my desk. And the 4th monitor is my TV which is across the room hooked in by a 25ft HDMI. The other 2 monitors are connected via DVI-D.
When i start my computer my bios will only display on the monitor i have hooked to the VGA port on my card. Which is also the monitor to the right of my main display. I would like my bios to display on my center monitor. I would just flip the VGA and DVI connections to get it centers, but the bios display is much clearer on the DVI and i want it to look nice and clean.
I tried unplugging all my monitors except my main display, the one i want the bios to display on. I restarted the computer thinking this would make it work.
After plugging all my monitors back in though my computer reverted to the setup i had originally.
My main display is considered my 2nd monitor according to my computer. And my TV is 1st. The VGA monitor is 3rd. I read that the number of the monitor you want it to be displayed on needed to be 1 but that doesn't seem to be the case here or it would display on my TV which it does not.
I have no other graphics cards installed.
Also, i tried switching the DVI cables up just to see if the monitors would switch, only at the graphics card. I just swapped them, but the displays did not change. Its like my graphics card knows which monitor is which no matter what port is it plugged into.
Does anyone know how i can force it to display on my DVI monitor? Or even on all monitors?
I'll be satisfied with either of those. I either want it to display on my center monitor on my desk, or i want it on every monitor. Any ideas?
