T tekken3 Reputable Feb 7, 2016 14 0 4,520 Mar 15, 2016 #1 When i try to open the game on windows 10 it shows "BioShockInfinite.exe - Entry Point Not Found The procedure point CreateInterface could not be located in the dynamic link library C:\Games\BioShock Infinite\Binaries\Win32\steam_api.dll" Help me
photonboy Titan Jun 20, 2006 21,566 13 85,015 Mar 15, 2016 #2 1. Was it working fine before? 2. If so, did you change ANYTHING at all since? 3. If not, did you try to VERIFY the game? Follow the "verify integrity of game cache" option: https://support.steampowered.com/kb_article.php?ref=2037-QEUH-3335 Upvote 0 Downvote
photonboy Titan Jun 20, 2006 21,566 13 85,015 Mar 15, 2016 #3 Update: *Yeah, so the same folder by default is in the "Documents" folder not the "Games" folder and mine has no data in it. I think the VERIFY option is the best bet unless you've incorrectly moved your data around. Upvote 0 Downvote
T tekken3 Reputable Feb 7, 2016 14 0 4,520 Mar 15, 2016 #4 Its the first time I'm playing it and I downloaded it from noSTEAM but now regretting wasting so much time Upvote 0 Downvote
photonboy Titan Jun 20, 2006 21,566 13 85,015 Mar 15, 2016 #5 tekken3 : Its the first time I'm playing it and I downloaded it from noSTEAM but now regretting wasting so much time Did you mean "noSTEAM" or simply the normal Steam program? Upvote 0 Downvote
photonboy Titan Jun 20, 2006 21,566 13 85,015 Mar 15, 2016 #6 Wait, did you PIRATE this game? If so, we can't help you with this. Upvote 0 Downvote
