Biostar mcp6p mobo problems
tripstuf
4
any fixes for biostar mcp6p m2+ motherboard problems? Mine freezes and turns off video...will not restart correctly unless you remove battery. Brand new board with AMD 7550 and 4gb Corsair DDR2 800mhz mem.
Could be a heat issue with the processor, but the 7550 isn't even listed under "cpu support" on biostar's website. You can try a bios flash, but you may already have the latest version. I have your board, and it won't reset the bios using the cmos jumper. You have to remove the battery to reset the bios. Must be a design quirk with the board. I use the sempron 1250LE that came with a frys combo special, and haven't had any special problems.
Only other recommendation is to remove the board and check for anything left under the board such as a misplaced standoff that could be causing a problem. Then reinstall the memory and check all connections. I use a 20 pin antec 350w ps, not the newest but it works even with a 24 pin connector. Could be the board doesn't get along with your power supply.
OKAY...finally figured out the BIOS sucked...went to Biostar Taiwan site and got flash dated 9-3-09 and upgraded....Installed fresh install of 7 Ultimate 64bit, it runs smooth and stable.
To anyone else with the video problem, upgrade the bios and add necessary drivers from Biostar site.
