Bitlocker failure NEED HELP
Tadej981
15
Recently I have encrypted my 3 Tb drive (with very IMPORTANT data) with Bitlocker. Everything was working fine. I often hibernated my PC (Win 7) and everything was fine. Until last time. When I tried to acess the disk a window opened "you need to format the disk in drive H: before you can use it". I clicked cancel. A window opened
"H: is not accessible
the volume does not contain a recognised file system.
If I look to disk managment it says, that a H: drive has a RAW file system.
If I go to control panel and bitlocker settings it says, that there are no external drives in computer.
I tried to reset the computer and replugging the drive. No changes.
I have both password and recovery key.
There are no dead sectors on the drive.
Any help appreciated, thanks in advance
+1. This is very true. At this point, if none of the scenarios helped, I would assume the data is gone and unrecoverable.
