3 years ago, I purchased 12 pc's from a prebuilt provider in the UK for work. All identical spec, all have worked flawlessly for 3 years until recently. I have had issues with 3 of these PC's which are all in the same office. It started off with one of the PC's initially and now all 3 have the exact same issue.
The symptoms were that they simply would not power on from the front panel power switch when shutdown overnight and turned on in the morning. This was an intermittent issue at first, only affecting one pc initially.
After unplugging from the mains and trying again several times, they would just suddenly come to life and power up. It got progressively worse with the first PC and I was convinced it was the power switch.
I replaced it and all was fine for a couple of days and it happened again. I was then thinking it was a PSU issue, so I replaced it with a tested fully working new one (same model) and it would still not power up. I then decided to short the power switch on the motherboard (should have done this first) and this did nothing. There was power to the mainboard as the lights on the mainboard were on and pulsating, but no fan movement at all from PSU, CPU or MB.
I was then thinking it must be another component or connection/cable issue. I literally took every component from the mainboard out, ram, gpu, ssd, all front panel connectors etc, so that it was basically a motherboard, cpu and PSU. Still NOTHING when shorting the power pins and using a switch. I also took out the CMOS battery for good measure.
At this point I was convinced that it must be the mainboard or cpu. I was at the point of taking the mainboard out of the chassis to see if there was some kind of chassis short. I left it overnight and decided to try again the next morning with a clean head as I was frustrated. It was on the workbench exactly where I left it. I shorted the pins and it powered on! I was amazed. I carefully connected all the components one at a time and it was fully working again, even the power switch. I tried shutting down, restarting multiple times and left it off for several hours and it fired up no problem every time. I was not sure what happened, but was just glad it was working again.
The most bizarre thing happened a few days later when the 2 other PC’s in the same office (exact same spec) were doing EXACTLY the same thing. I did the same thing, stripped them down and they would not power up at all even when shorting out the pins. I left them overnight again last night and guess what? Today they both powered on, no problem.
Please can someone explain this as I have NEVER come across anything like this before. We have 9 more of these PC's in other departments and they are working just fine. I thought there could be a power spike issue in the office, but I was working on these pc's in my own office in another building. Here are the specs:
CPU - AMD Ryzen 5 3600X
Motherboard - ASUS PRIME B450-PLUS
Memory - 8GB Corsair VENGEANCE DDR4 2666MHz (2 x 4GB)
Graphics Card - 1GB NVIDIA GEFORCE 710 - DVI, HDMI, VGA
SSD - 250GB Samsung 860 EVO 2.5"
Power Supply - CORSAIR VS-350
