blade servers tend to be cheaper for each server, once the enclosure is bought but that basically means the cost comes out the same. blades give you a higher rack density, you are sharing power modules for the whole enclosure. blade enclosures are easier to manage as a single unit with common monitoring software, kvm etc... and then once you start adding switching modules, you start to get some more advantages regarding saving space, cable management etc...
