Blue Screen Of Death HELP
L3THALSHADOWz
25
So far on this PC i have built i have received the BSOD about 3 or 4 times. These are my specs
AMD FX 8320
Asus HD 7790 Direct CU II OC 1 GB Graphics Card
Crucial BLT4G3D1608DT2TXRGCEU 4GB Ballistix Smart Tracer Memory
500GB WESTERN DIGITAL HARD DRIVE
120GB FUJITSI HARD DRIVE(JUST ADDED RECENTLY FOR RECORDING HAD BSOD BEFORE ADDED)
XFX 550W PSU
Can anybody tell me why i am getting the BSOD is it heating problems or something becuase all my temps are normal.
What does the error say, first?
Second, if its a heating issue, when you turn it on.
Does it turn right back off(go to BSOD) after a cold start or does the fans speed increase?
No it doesn't turn back off it just starts up like nothing happened. where can i go back to to see what the error was?
Extra information about the problem
BCCode: a0000001
BCP1: 0000000000000005
BCP2: 0000000000000000
BCP3: 0000000000000000
BCP4: 0000000000000000
OS Version: 6_1_7601
Service Pack: 1_0
Product: 256_1
Problem Event Name: BlueScreen
OS Version: 6.1.7601.2.1.0.256.48
Locale ID: 2057
I built this computer about 3 months ago and have had the error about 4 times. so could it just be a simple error or is it going to get worse?
Last couple things I wanna ask. Have you changed anything within your settings?
Does it only occur with a specific program?
If so of any of the above. Change it back or remove the program that causes it only when using that program.
Also make sure your running the latest drivers.
Still leaning towards a memory dump error, this is if its only occurring every so often.
It probably is just a memory dump error because i just had it now whilst on youtube. and i have not changed anything
