Hello guys,
I don't know what to do anymore. I asked around, googled a lot and tried even more things that could possibly fix my current problem. I recently got a new PC and since day 1 it has some very strange behavior. Luckily I am able to narrow it down more and more but I'm not a pro in terms of PC parts so I can't really find a solution that really fits. I try to give you as much information as I can and if you need any more info, feel free to ask, I'll try to provide anything that could help.
Description of the problem:
Every now and then when I was playing games the screen would get black (with some fuzziness, screenshot down below) and shortly after the PC would crash. I tried a few things here and there, including BIOS update and changing some BIOS settings (see screenshots attached). Meanwhile these weird blackscreens have turned into "normal" bluescreens with some exceptions. First I noticed the crashes every time I was playing a specific game but since I installed more and more games I noticed it crashes while playing other games too. Currently I have the feeling that it tends to crash whenever I tab out/leave/exit out of a performance heavy task. Closing Steep (game) on ultra settings or tabbing out of Valorant while streaming with OBS (streaming software), these are just examples, other Games/Software sometimes have the same behavior.
Things I've changed/done so far:
Every time a crash/reboot occurs I check the event viewer afterwards. This is what it tells me (rough translations because my system is not english):
I really hope someone in this forum can help me find the solution. It is really frustrating to always expect random reboots in the middle of work, gaming and streaming. The only idea that I have left for now: Buying a different brand of RAM because I've read a couple of times that the RAM might not be compatible with the CPU.
Best wishes
- I run memtest86, it took about 4.5 hours and returned everything is okay.
- I downloaded OCCT and checked temperatures + did various tests, everything seems normal (at least to me)
- I updated my BIOS to the most current stable version at the time (I think there has been a new release a couple days ago, maybe I'll try this next)
- Checked every driver in device manager for updates, everything seems up to date
- AMD Ryzen 7 5800X
- MSI GeForce RTX 3070 Gaming X Trio 8G
- MB: MSI MAG B550 Tomahawk
- RAM: 32GB G.Skill Trident Z RGB 3200 CL16
- PSU: Corsair RM750X
- Error / EventLog / ID 6008
- The system was unexpectedly shut down
- Error / volmgr / ID 161
- Dump file creation failed due to error during dump creation
- Critical / Kernel-Power / ID 41
- The system has rebooted without cleanly shutting down first. This error could be caused if the system stopped responding, crashed, or lost power unexpectedly.
- Error / WHEA-Logger / ID 18
- A fatal hardware error has occurred.
Reported by component: Processor Core
Error Source: Machine Check Exception
Error Type: Bus/Interconnect Error
Processor-APIC-ID: 0
Error Type: Cache Hierarchy Error
Processor-APIC-ID: 15
- Fuzzy blackscreen (stays like that for 3-4 seconds then PC reboots)
- BIOS current voltages
- BIOS settings 1
- BIOS settings 2
Best wishes
