[SOLVED] BlueStacks Access Hard Drive Files Help
Seraph2
6
Hi, I am using BlueStacks emulator and I am trying to access the files on my
hard drive so that I can copy them into the BlueStacks storage so that I can
use them in BlueStacks and I googled that you are supposed to use a programme
called Media Manager but I don’t see it on the play store anywhere and I can’t find
a place to download the apk so if someone can give me an address where I could
download it or maybe if you know of another way that I could access my hard drive
from inside BlueStacks that would be great, any help would be appreciated thanks.
I did find the Media Manager that is already there but when I go into it, it is just a blank white page?
After reading your answer I went back and had another look at it and I tried that Media Manager again and now it loads through perfectly I can see the (Import From Windows) button and everything, it was probably just an error or something, anyway thank you for the help guys.
Reactions: Spaceghaze
