[SOLVED] bluetooth device connection (2 device at same time)
Vyns__
19
I have a Sony WH-CH500 headset that works perfectly with my PC using an EKO Bluetooth 4 USB Adaptor.
I have the new Microsoft Elite Controller 2, that also works perfectly with the same adaptor.
When I connect both, for gaming even though I'm not touching the controller, the audio is stutter at best and sounds speeded up.
Can Bluetooth support 2 devices at once? Or do I need a better Bluetooth adaptor.
NOTE: The adaptor I have is this one...>
https://www.amazon.co.uk/gp/product/B01D3Q0228/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
My PC is fairly up to date;
I7 6700K
RTX 2060
16Gb Ram
several USB 2 and USB 3 ports
Thanks in advance..
bluetooth can support alot of devices, but your BT 4.0 is limited to 0.3MB bandwith limit
if your headset struggles with another devices connected, then you will need more bandwith as audio transfer is data hungry
BT 5.0 has 2MB bandwith limit
