bluetooth headset connects but appears disconnected on sound device
both radio and microphone is enabled but still no result. I tried going into hardware and sound > devices and printers then going to the headset and enabling all the services but still no change. Sometimes the headset says something that sounds like "connection failed". Maybe that helps to find the solution?
Hello again
Can you please check and confirm if the Bluetooth driver is up-to-date? If not, updating it to the latest version may help.
Also, if the driver is already updated, and the update occurred recently, rolling the driver back to its earlier version might do the trick.
Cheers!!
I tried. Almost ended up not being able to pair it again. Also tried installing older versions of bluetooth but still nothing.
Yes but still no changes. But after a few seconds from restarting the headset correctly connected but when i tried connecting the headset again it didn't work.
