Bluetooth (Wireless); Compatibility
  • Thread starter Thread starter Guest
  • Start date Start date
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.hardware (More info?)
I'm looking to buy a Wireless Bluetooth mouse for my laptop. I do not
believe my laptop is "Bluetooth-enabled" with a Bluetooth adapter built in.
Can I just use one of the existing USB 2.0 ports? One of the mice I was
looking at, put out by Kensington does not come with an adapter, because it
was made for computers that are already "Bluetooth-enabled". You can check
it out here:
http://www.buy.com/retail/product.asp?sku=10365412&loc=101&hdwt=22117&sp=1.
I have Windows XP Home SP2 installed. Is that enough to make this mouse
work, or do I need to buy one with an adapter? I was thinking about this
one, too:
http://www.buy.com/retail/product.asp?sku=10373942&loc=101&hdwt=22117&sp=1.
I wasn't sure if I just need to install a driver, in order to use a bluetooth
mouse adapterless.
It seems like I need an adapter, just like I need a wireless adapter in
order to connect to my LAN/WLAN.
Thank you very much for your time.
If your laptop does not have a BlueTooth card built into it, you will
need to buy a BlueTooth Dongle to make that mouse work. I would
recommend buying a BlueTooth mouse that comes with the Dongle as they
are going to be paired and will work for sure. With BlueTooth being a
new technology (and often slightly altered), it is possible that some
BlueTooth products may not support one another.
Nathan McNulty
Swap gmail with name for email :)
> it out here:
> one, too:
> mouse adapterless.
