Boot Monitor Problems
G
Guest
Guest
Archived from groups: alt.comp.periphs.mainboard.abit (More info?)
I have recently put a machine together using the ABit NF7_M Motherboard my
problem is that when I switch the computer on the monitor will sometimes not
kick in I have to power down the monitor switch it on again and switch the
computer on and everything goes as it should this happens with at least 3
different monitors. Anybody help.
256mb DDR 2700 using onboard gfx set at 64 MB
JAMES ABEL said in news:c7r0g1$79f$1@sparta.btinternet.com:
> Motherboard my problem is that when I switch the computer on the
> monitor will sometimes not kick in I have to power down the monitor
> switch it on again and switch the computer on and everything goes as
> it should this happens with at least 3 different monitors. Anybody
> help.
Is the BIOS configured to use the correct slot type for the video? Often
there is a setting where you choose which video device to boot from first,
PCI or AGP. If you have an AGP video card, set this to use AGP video first.
____________________________________________________________
*** Post replies to newsgroup. Share with others.
*** Email: domain = ".com" and append "=NEWS=" to Subject.
> different monitors.
Probably some wire that is almost broken in the monitor cable.
Have you been bending that cable a lot?
It happens on at least 3 different monitors.
"Jens C. Hansen [Odense]" <"Jens C. Hansen [Odense]"> wrote in message
news:40a106f8$0$156$edfadb0f@dtext02.news.tele.dk...
my
not
the
> > different monitors.
Ah, sorry. I read it the other way around.
Try another PSU then, it might not deliver enough voltage at boot-time.
The "Codegen 300X" is a known trouble-maker..
I`ve heard of this before if the problem persists I`ll try that.
Thanks
news:40a1285f$0$181$edfadb0f@dtext02.news.tele.dk...
