Boot up problem
David
2,039
Archived from groups: microsoft.public.windowsxp.basics (More info?)
Sometimes it takes half an hour to boot up my machine. I get a recurring
message apologising for inconvenience. It gives options to: start in safe
mode, ditto with command prompt. Mostly it counts down from 30 seconds to
zero before trying to boot again. Help Please!
Hi
The count down is in the boot.ini file and can be altered. What is the
exact error message that you see?
Will Denny
MS-MVP Windows Shell/User
Please reply to the News Groups
"David" <doris.s@ntlworld.com> wrote in message
news:0zECd.1273$9H4.748@newsfe2-gui.ntli.net...
Can't remember exact message - it's a long one! talks about soemtimes
happening after new software or hardware has been installed (which it
hasn't). Another option given is to start in last known configuration, which
I've tried without success. BTW all this error message is white on black as
if in DOS mode!
"Will Denny" <willdenny@mvps.org> wrote in message
news:%23ul6X1q8EHA.2192@TK2MSFTNGP14.phx.gbl...
> Hi
> Will Denny
>> to zero before trying to boot again. Help Please!
Hi
Have you tried a System Restore via Safe Mode? If yes, and 'Last Known Good
Configuration' doesn't work, you'll have to try a 'Repair' install of XP.
Will Denny
news:TgFCd.402$II4.292@newsfe5-win.ntli.net...
> which I've tried without success. BTW all this error message is white on
> black as if in DOS mode!
>> Hi
>> Will Denny
>>> safe mode, ditto with command prompt. Mostly it counts down from 30
>>> seconds to zero before trying to boot again. Help Please!
Does 'Repair' install just mean putting the disk back in as if in a new
install? If so, I'll try that nrxt.
news:uYd5chr8EHA.4004@tk2msftngp13.phx.gbl...
> Hi
> Good Configuration' doesn't work, you'll have to try a 'Repair' install of
> XP.
> Will Denny
>>> Hi
>>> Will Denny
>>>> recurring message apologising for inconvenience. It gives options to:
>>>> start in safe mode, ditto with command prompt. Mostly it counts down
>>>> from 30 seconds to zero before trying to boot again. Help Please!
Hi
The following article by Michael Stevens will show you how to perform a
'Repair' install of XP:
"How to Perform a Windows XP Repair Install"
http://michaelstevenstech.com/XPrepairinstall.htm
Will Denny
news:ZvMCd.22$073.0@newsfe1-win.ntli.net...
>> Hi
>> of XP.
>> Will Denny
>>>> Hi
>>>> Will Denny
