[SOLVED] Bootcamp for Snow Leopard Help
slam9996
Commendable
Apr 23, 2016
Hi I have a 2006 (1,1) mac mini 32bit running Snow Leopard. I am trying to repurpose it. I am having trouble using bootcamp to install windows. I have tried windows 7,8,10 and every time get the black screen select cd rom boot type 1 and 2 and the keyboard does not work. https://www.technopat.net/sosyal/eklenti/img_3841-jpg.41975/
The only things I can find on this issue on other forms has to do with people trying to install 64 bit versions instead of 32 bit. I have tried 32bit and 64bit and no luck. I also would like to add that this is a stock mac mini hardware wise no upgrades whatsoever. I have also tried just booting directly into the cd during startup same select cd rom boot type screen. Also, I have used retail cds and have even download iso's with no success.
Thank you for your help
Latest posts
