Hello, i used to have a pc with the following specs:
Celeron 450 single core cpu
2gb (unsure of speed) dual channel samsung ddr2
Foxconn socket 775 mobo
Onboard graphics (gma 950?)
7200rpm 320gb WD Caviar blue sata hdd
Windows vista likely 32 bit (never updated since 2009 when the computer was originally purchased since the pc never had an internet connection)
I dont know much more about this computer since most of the components were long lost back when i didnt know as much about computers.
I still have the HDD from this computer lying around as well as the origional vista install disk. The disk might say 32 bit or 64 on it ill have to check. When i plug the hdd into my main ryzen based pc using a usb hdd adapter, the os begins to startup and then goes to a recovery menu. Trying to get to the startup repair settings yields a bsod. The pc boot loops back into a recovery menu if i try to start windows normally. I assumed my ryzen cpu was the reason for this issue so i plugged the drive into an ivy bridge i5 laptop using the same adapter and got the same result. The ivy bridge laptops cpu has graphics drivers for xp so i would assume the i5 3337u cpu supports windows xp and because of that would support vista since the drivers on vista using xp dm.
Is there a way to boot from that hdd and get past the boot failure using hardware other than the original? I do not have the old pc to check with. The oldest system i have has a 3rd gen i5. I may be able to borrow an fx6300 system to check.
I currently have a pc running windows 10 with the following specs:
Ryzen 3 1200
MSI b350 gaming +
Gtx 1050 pny
I have an old hdd from a computer that came with a celeron 450 and on board gpu. This hdd has a 32 bit copy of windows vista last updated in 2009.
I have several games on there that simply wont run on windows 10. I want to run this windows vista hdd in my pc and eventually have a hdd with windows xp running on this pc. I am aware Ryzen doesnt support win7 or older. I still want to run vista on my pc and play these older games.
The problems: Have a gotten the hdd mounted in my pc using sata. When i boot from the hdd the computer immediately throws up a vista recovery menu. If i select to run windows normally the pc restarts. I can disable automatic restarts by holding f4 when the pc boots this allows me to see the error code. It isnt specific, stating fauly hardware, hdd, or drivers (most likely) were the culprit. If i use the repair option instead of start win normally i get further. I get to a screen with a b&w vista wallpaper and startup repair menu. It scans the pc for faults and states that it cant fix my pc. It gives me more options if i enter my password. I couldnt remember mine so i brought out my trusty password cracker live cd. This wouldnt work on ryzen either but i put the vista hdd and cracker usb key in an ivy bridge laptop and found my password. Booting vista on this laptop yielded identical results. Back in my ryzen pc i booted vista, entered the pw, and got to more options here i can get many diagnostic tools. I have ran memory diagnostic to no avail. I can access cmd aswell.
Any ideas how to make this work?
Ryzen 3 1200
MSI b350 gaming +
Gtx 1050 pny
