D dylancobb1 Reputable Nov 1, 2014 3 0 4,510 Nov 2, 2014 #1 If i use a 8350 oc at 4.7 ghz will it bottleneck a 3 way 970 sli or will it be perfectly fine ?
Solution I I i7Baby Nov 2, 2014 It'd be getting close. Like using a weak i5. http://cpuboss.com/cpus/Intel-Core-i5-4690-vs-AMD-FX-8350
I i7Baby Titan BANNED Jul 25, 2012 44,080 2 106,960 Nov 2, 2014 Solution #2 It'd be getting close. Like using a weak i5. http://cpuboss.com/cpus/Intel-Core-i5-4690-vs-AMD-FX-8350 Upvote 0 Downvote Solution
G GRUxTSAR Reputable Aug 8, 2014 1,479 0 5,660 Nov 2, 2014 #3 You'd likely bottleneck. 3x 970s is pretty high end stuff. You should go with 2 and think of upgrading your CPU Upvote 0 Downvote
anbello262 Distinguished Sep 27, 2013 1,179 3 19,915 Nov 2, 2014 #4 Actually, 8350 in well threaded games is like a weak i5. In less threaded games is a lot lower than that, even... So yes, in most games there will be a big bottleneck. In the rest, a small one. Upvote 0 Downvote
