[SOLVED] Bought Ryzen 5 5600X @ Retail Price - Need help to upgrade my current PC
BrainY
395
Current System
CASE: Fractal Design Define R4 Black Pearl (Stock Fans)
CPU: Intel Core i5 4670K Haswell OC with Noctua NH-D14
MOBO: ASRock Z87 Extreme4
GPU: ASUS ROG Strix GeForce GTX 1070 O8G-GAMING
RAM: 2 x 8GB G.SKILL Sniper Series 16GB (2 x 8GB) DDR3 2133 (PC3 17000)
SSD: Toshiba OCZ TR150 2.5" 960GB SATA III
HDD: Samsung Spinpoint F3 500GB 7200RPM 16Mb 3GB/s
PSU: OCZ ModXStream Pro 600W
Upgraded System
CASE: Keep
CPU: AMD Ryzen 5 5600X 3.7 GHz 6-Core Processor (Bought today)
MOBO: New (~ 130USD) - Thought about this selection
GPU : Keep
RAM: New (~120USD) - Thought about this selection
SSD: Keep
HDD: Keep
PSU: New (~120USD) - Thought about this selection
Question: I noticed the Ryzen 5 5600X can support up to 3200 speeds on RAM. Does that mean anything faster will be bottlenecked?
Any builds would be appreciated! I added my selection of parts I have considered. I'm still debating on a cheap AIO Water Cooler or a good Air Cooler.
I know I have the Noctua but the thing is sooo old and barely fits in my case. I do have a window but I don't mind color mismatches or something ugly. I'm looking for Performance > Costmetics
Mobo: I read and watch good reviews about this ones (no particular order):
Asus TUF GAMING B550M-PLUS
MSI MAG B550M BAZOOKA
Gigabyte B550M AORUS PRO-P
MSI B550M PRO-VDH WIFI
RAM (more than enough): G.Skill Flare X Series 16 GB (unless you need/want RGB, then pick any of the other kits listed that comes with it)
PSU, I believe your PSU link is wrong, anyways:
https://pcpartpicker.com/product/64...fied-fully-modular-atx-power-supply-ssr-750fx
Cheers
Current System
Upgraded System
CASE: Keep
GPU : Keep
SSD: Keep
HDD: Keep
You are going to replace your D14?! Madness I say 😛
Reactions: RodroX
Cheers
PCPartPicker Part List
CPU: AMD Ryzen 5 5600X 3.7 GHz 6-Core Processor (Purchased For $325.00)
CPU Cooler: Noctua NH-D14 64.95 CFM CPU Cooler (Purchased For $0.00)
Motherboard: MSI B550M PRO-VDH WIFI Micro ATX AM4 Motherboard ($108.99 @ Amazon)
Memory: *G.Skill Flare X Series 16 GB (2 x 8 GB) DDR4-3200 CL14 Memory ($114.99 @ Newegg)
Storage: OCZ TRION 150 960 GB 2.5" Solid State Drive (Purchased For $0.00)
Video Card: Asus GeForce GTX 1070 8 GB Video Card (Purchased For $0.00)
Case: Fractal Design Define R4 ATX Mid Tower Case (Purchased For $0.00)
Power Supply: SeaSonic FOCUS Gold 750 W 80+ Gold Certified Semi-modular ATX Power Supply ($103.99 @ Amazon)
Operating System: Microsoft Windows 10 Pro OEM 64-bit (Purchased For $0.00)
Monitor: Asus MG248Q 24.0" 1920x1080 144 Hz Monitor (Purchased For $0.00)
Total: $652.97
*Lowest price parts chosen from parametric criteria
Generated by PCPartPicker 2021-02-02 11:35 EST-0500
Reactions: Flayed
Reactions: RodroX
