Brand new build wont post and cpu fan not spinning
pinguin05365
18
My brand new computer wont post the screen just stays black doesnt come out of sleep i notice that the cpu fan doesnt start spinning everything else works any troubleshooting i can do ? (First build) i checked the cable and the pins where the cpu fan plugs in and i see no problems im a little bit scared since this is my first build and i think i broke something what can this be or how can i fix it any ideas ?
Specs:
motherboard : asus prime b350-plus
Cpu: amd ryzen 5 1600X
Case: nzxt s340
Ram : corsair vengeance lpx 16 gb 2x8gb
Psu: cooler master v650 80+gold
Cpu cooler : thermalright le grand macho rt
Video card: msi geforce gtx 1070 8gb
ok. Now to put it in the case. Power off. Remove the graphics card and power cables.
Check the case standoffs. Make sure that each standoff does match a board screw hole.
Install the board, power cables, graphics card and test again.
Alexoiu thank you so much for helping me i really appreciate it man your the best haha now my pc works i installed windows i just build the system up like you said out of the case then tested it and added part after part till it was complete and everything is function correctly i just flashed a new bios version im gonna look at some temps right now run cinebench and then start overclocking thanks bro :)
