Hi..just wanna ask..
whats the difference with the branded LED strips that are specifically made for pc case and the ones that you can buy on your local hardware stores for general lighting use??cause i saw someone buy an led strip from a local hardware and asked the guys there to change the wiring so he can attach it to his power supply
many thanks to those that will answer
