Hello,
I want to ask a question, so im encountering Double NAT.
The only way i know how to fix it is enabling Bridge Mode, but i don't have that as an option in my router settings.
I've contacted my ISP, and they told me to disable DHCP, so i did that, everything worked fine, but
my digital box started having issues, saying "IP Address could not be found", so basically disabling DHCP removed the internet
from my digital box, which is bad since it's required for TV.
Could i get a switch, and plug the digital box to the switch, or something?
Since the digital box is taking up the router's WAN port, and all the computers are in LAN ports.
My router: Zyxel LTE 3306-M604
