Brightness problem
OnlyAlex
Commendable
Sep 16, 2021
303
22
1,685
Hi everyone, I have an ASUS Rog Strix G16 which is just over a month old. I had an odd problem today with changing the brightness settings. I have two display adaptors which are up to date:
1. Intel UHD Graphics
2. NVIDIA GeForce 4070 GPU
When I pressed the brightness up and down buttons, the indicator pops up on screen on Windows 11, but the brightness didn't change. I think I have had this problem once before since purchasing, but a simple restart worked which after troubleshooting worked again today.
Does anyone have any advice? Is this is a major issue? Not really sure what to do. It seems to me maybe it's just a temporary glitch rather than hardware issue?
Thanks.
Temp Glitch. Kinda happened to me after switching out my 60hz panel with a 120Hz on my 2017 Predator Helios 300.
Thank you very much, that's re-assured me a lot as I was a bit concerned - but it makes sense as it was put into sleep, then I plugged and unplugged where it goes from 240hz to 60hz and then plugged back in.
Reactions: NanoSuit3
Yeah & also that certain laptops with Nvidia Optimus can sometimes have trouble switching from high to lower refresh rates as I've been seen or told; but Idk about todays modern.....................Hmmmmmmmm........................
Reactions: OnlyAlex
It seems to me that modern technology is so advanced that half the time it doesn’t work properly!
