D dlenchert57 Honorable Jul 15, 2018 75 0 10,540 Aug 3, 2018 #1 I have a 1 tb hard drive and it was not working. when i took it out and looked at it, the sata power connection was destroyed. does anyone know how to fix it? https://imgur.com/a/HYE5Kp2
Solution SkyNetRising Aug 3, 2018 Not worth it. Just replace it. You'd need to get a donor drive with same design sata connector. Remove the connector from donor drive and solder it to your drive.
SkyNetRising Titan Jan 4, 2016 32,748 4,827 126,640 Aug 3, 2018 Solution #2 Not worth it. Just replace it. You'd need to get a donor drive with same design sata connector. Remove the connector from donor drive and solder it to your drive. Upvote 0 Downvote Solution
