Nothing much on this to fix over the internet, this is a physical issue you need to check on the printer. Were the replacements done with generic parts or OEM Brother parts? All you can do is check over the setup. Make sure they are all clicked in properly, all cleaned including the corona wire if there is one. Check if the paper gets crumpled when fed through manual feed as well, that may be able to tell you where the issue is starting.
