I've got a computer I'm trying to fix, and I would rather not reformat. I may reformat, but I really want to know what the problem is first.
Here's what is happening:
Computer won't boot at all. Not even in Safe Mode
Last known config. doesn't work.
Startup Repair unable to fix it.
No restore points.
Repair disk (for a 64bit, so that may be the problem :/ )
Startup repair detects no problem.
Chckdsk /f detects no problem.
I've booted into HBCD and got the Minidump files, but idk what to make of them. I even used "whocrashed" and I'm not sure how I can fix it.
Anyway, here are the files in a .7z format. If you can look at them, or give any advice, I'd be very appreciative!
Minidump files on Skydrive http://sdrv.ms/1e1pGR4
EDIT:
Also, Memory test is fine.
I enabled bootlogging just now.
Here is the ntbtlog.txt
Google Drive https://docs.google.com/file/d/0BxrhSOkdWnSKal9WVVVOTS1iTWc/edit?usp=sharing
No restore points.
EDIT:
