Question BSOD - - - -> "Driver Power State Failure" ?
Sep 29, 2023
Hello. I have been getting weird driver and PC crashes on startup and if it doesn't crash on startup, everything is fine afterwards. I would appreciate any help. Thank you!
Computer Type: Desktop
GPU: RX 7900 XT
CPU: RYZEN 5 7600X
Motherboard: B650 AORUS Elite AX
BIOS Version: F8
RAM: 32GB G.Skill Trident Z5 Neo RGB DDR5-6000
PSU: Corsair RM850x 80 PLUS
GPU Drivers: 23.11.1
Description of Original Problem: Receiving high voltages, cpu temps, and frequencies while idle according to hwinfo64. IDLE CPU TEMPS: 45-65c IDLE VOLTAGES: 1.475. IDLE FREQUENCIES: 3.4GHz-4.3GHz. AMD Ryzen Master shows regular temp in the 40s as well as regular voltages of 1.00-1.2. I don't know what program to believe.
Troubleshooting: I've tried setting Ryzen balanced and Ryzen high performance as well as windows balanced and performance yet hwinfo still shows high temps. When I disable both Core performance boost and Percision boost overdrive, temps drop to the low 40s in hwinfo. I still want my CPU to boost but not when idle.
Here is the info from minidump: DRIVER_POWER_STATE_FAILURE (9f) A driver has failed to complete a power IRP within a specific time. Arguments: Arg1: 0000000000000003, A device object has been blocking an IRP for too long a time Arg2: ffffa10a592430a0, Physical Device Object of the stack Arg3: ffffb287b9447178, nt!TRIAGE_9F_POWER on Win7 and higher, otherwise the Functional Device Object of the stack Arg4: ffffa10a59d159a0, The blocked IRP
Debugging Details:​
Implicit thread is now ffffa10a`718df040 *** WARNING: Unable to verify timestamp for AtihdWT6.sys *** WARNING: Check Image - Checksum mismatch - Dump: 0x35a22, File: 0x35c3c - C:\ProgramData\Dbg\sym\HDAudBus.sys\D38B55132f000\HDAudBus.sys
KEY_VALUES_STRING: 1
Key : Analysis.CPU.mSec
Value: 1499
Key : Analysis.Elapsed.mSec
Value: 20541
Key : Analysis.IO.Other.Mb
Value: 22
Key : Analysis.IO.Read.Mb
Value: 0
Key : Analysis.IO.Write.Mb
Value: 37
Key : Analysis.Init.CPU.mSec
Value: 124
Key : Analysis.Init.Elapsed.mSec
Value: 34150
Key : Analysis.Memory.CommitPeak.Mb
Value: 106
Key : Bugcheck.Code.LegacyAPI
Value: 0x9f
Key : Failure.Bucket
Value: 0x9F_3_HDAudBus!HdaController::TransferCodecVerbs
Key : Failure.Hash
Value: {d537d977-4d49-4313-8130-09cc882bd617}
Key : WER.OS.Branch
Value: ni_release
Key : WER.OS.Version
Value: 10.0.22621.1
BUGCHECK_CODE: 9f
BUGCHECK_P1: 3
BUGCHECK_P2: ffffa10a592430a0
BUGCHECK_P3: ffffb287b9447178
BUGCHECK_P4: ffffa10a59d159a0
FILE_IN_CAB: 112823-13000-01.dmp
DRVPOWERSTATE_SUBCODE: 3
FAULTING_THREAD: ffffa10a718df040
BLACKBOXBSD: 1 (!blackboxbsd)
BLACKBOXNTFS: 1 (!blackboxntfs)
BLACKBOXPNP: 1 (!blackboxpnp)
BLACKBOXWINLOGON: 1
CUSTOMER_CRASH_COUNT: 1
PROCESS_NAME: System
STACK_TEXT:
ffffb287bc8b6270 fffff80112e6d645 : ffffd7007be61180 0000000000000000 ffffa10a50bce080 0000000000000000 : nt!KiSwapContext+0x76 ffffb287bc8b63b0 fffff80112e6f827 : ffffa10a718df1c6 0000000000000000 0000000000000000 0000000000000000 : nt!KiSwapThread+0xab5 ffffb287bc8b6500 fffff80112e71746 : ffffa10a00000000 ffffb28700000001 ffffb28700000000 0000000000000000 : nt!KiCommitThreadWait+0x137 ffffb287bc8b65b0 fffff8018de429bd : ffffa10a58e90000 ffffa10a58e90000 0000000000000001 ffffa10a79996120 : nt!KeWaitForSingleObject+0x256 ffffb287bc8b6950 fffff8018de427c2 : ffffa10a58e90000 ffffa10a58e90000 00000000ffffffff fffff801136ac2b0 : HDAudBus!HdaController::TransferCodecVerbs+0x17d ffffb287bc8b69f0 fffff8018711ae87 : 0000000067447a41 ffffa10a59b98a90 ffffa10a7aa7de70 0000000000000100 : HDAudBus!HdaBusInterface::TransferCodecVerbs+0x202 ffffb287bc8b6aa0 0000000067447a41 : ffffa10a59b98a90 ffffa10a7aa7de70 0000000000000100 0000000000000000 : AtihdWT6+0xae87 ffffb287bc8b6aa8 ffffa10a59b98a90 : ffffa10a7aa7de70 0000000000000100 0000000000000000 ffffa10a59b98a90 : 0x67447a41 ffffb287bc8b6ab0 ffffa10a7aa7de70 : 0000000000000100 0000000000000000 ffffa10a59b98a90 0000000000377a00 : 0xffffa10a59b98a90 ffffb287bc8b6ab8 0000000000000100 : 0000000000000000 ffffa10a59b98a90 0000000000377a00 8000000000000000 : 0xffffa10a7aa7de70 ffffb287bc8b6ac0 0000000000000000 : ffffa10a59b98a90 0000000000377a00 8000000000000000 ffffa10a5878ed50 : 0x100
SYMBOL_NAME: HDAudBus!HdaController::TransferCodecVerbs+17d
MODULE_NAME: HDAudBus
IMAGE_NAME: HDAudBus.sys
IMAGE_VERSION: 10.0.22621.2771
STACK_COMMAND: .process /r /p 0xffffa10a50b84040; .thread 0xffffa10a718df040 ; kb
BUCKET_ID_FUNC_OFFSET: 17d
FAILURE_BUCKET_ID: 0x9F_3_HDAudBus!HdaController::TransferCodecVerbs
OS_VERSION: 10.0.22621.1
BUILDLAB_STR: ni_release
OSPLATFORM_TYPE: x64
OSNAME: Windows 10
FAILURE_ID_HASH: {d537d977-4d49-4313-8130-09cc882bd617}
Followup: MachineOwner
No worries, I'll get to it as soon as I'm able.
FWIW that bugcheck indicates that a device failed to respond to a power transition in a specific time. The dump will tell me which device it actually is, but from the stack trace in the analyze -v output you posted it's likely to be an audio device.
