Hello! While I am a software engineer, this is definitely not my area, so any help you can give is much appreciated! I'm going to give as much detail as I can here, but if you need more details, let me know. I'm not sure how much of this is related or separate problems.
Laptop: Alienware m17 R5 AMD
OS: Windows 11 Home Edition (checked for updates, it is fully up-to-date)
For some time now (and Dell support has been no help, despite this still being under warranty), the laptop has been booting up directly into the Alienware hardware check utility. It does this because it suspects a hardware issue, but the tests always pass. Windows loads fine after the check. I haven't been able to troubleshoot this as much as I've wanted to, due to some very difficult recent life events.
I finally had some time to do a little debugging and discovered that this only happened when the wireless mouse fob was plugged in, though so far I've only been using the one port I always plug that into. I could reliably reproduce the boot-up hardware check or lack thereof by plugging in or unplugging that fob. I thought, okay, I'll plug other things into the port and test, but before I was able to do that, I had a Zoom meeting. I had a webcam plugged into that port, intending to test the reboot after the Zoom. But, during the Zoom, the webcam sizzled and dimmed. I immediately pulled out the plug from the USB. The webcam is fried, it doesn't work anymore.
This is when the BSODs started. After a little bit of debugging on that, I realized that it only happens when the laptop is unplugged. Again, I can reliably reproduce this; within minutes of unplugging the computer, the BSOD happens. I've had four of them so far. WinDbg analysis gives the same bugcheck code each time, 20001, hypervisor. Dell told me to turn off Hyper-V, but this is Windows 11 Home; there is no Hyper-V on it. They told me to reinstall Chrome and turn off hardware acceleration in the settings. I tried first turning off hardware acceleration, but it didn't help. I haven't reinstalled it yet. I am skeptical that Chrome is the issue, since only one of the BSODs referenced Chrome as the process name. The others are System (twice) and AWCC.Backgroun.
Dell doesn't think this is a hardware issue, so, they are refusing to send a technician out at all. I bought a USB multimeter. Readings so far are between 5.18v and 5.21v from all three USB-A ports, while the laptop is plugged in. No power is coming from the USB-C port at all, but again, I'm not a hardware person, so maybe that's normal. Next, I will try to get MM readings after unplugging the laptop's power cord, see if anything changes there after it is unplugged. Since that will cause a BSOD, I'll come back here and update this with those results.
I've also downloaded and run USBTreeView, a great tool for looking at the USB hierarchy. If there is any data desired from that, let me know and I'll add it here.
