BSOD Help IRQL_NOT_LESS_OR_EQUAL
alexharsh
4
I've been getting this bsod over and over and I don't have a solution to fix it despite all the research I've done on it
Pc specs:
i5 6600k OC to 4.3 GHz
8gb ddr4 2133 memory
GTX 970
120917-11187-01.dmp 12/9/2017 9:46:46 PM IRQL_NOT_LESS_OR_EQUAL 0x0000000a 00000000`00000001 00000000`000000ff 00000000`00000029 fffff802`f70e624a ntoskrnl.exe ntoskrnl.exe+1640e0 NT Kernel & System Microsoft® Windows® Operating System Microsoft Corporation 10.0.16299.64 (WinBuild.160101.0800) x64 ntoskrnl.exe+1640e0 C:\WINDOWS\Minidump\120917-11187-01.dmp 4 15 16299 521,948 12/9/2017 9:47:30 PM
J7vqX
I would start by running MEMTEST86 for a full pass. www.memtest86.com
Also set the CPU back to default settings, and the memory to "XMP" profile.
If that doesn't solve the issue, stay with those default settings until the problem is fixed.
The NEXT thing I'd try is to do an In-Place Upgrade:
1) download MS media creation tool (just Google)
2) insert 8GB+ USB drive
3) run the above tool to download and create W10 install media (need latest version so can't use an old disc)
4) run "setup.exe" from that stick and follow instructions (should not delete apps or data)
That should overwrite some key files which MAY fix your issue.
