[SOLVED] BSOD HELP
Jun 22, 2020
27
Hello,
I've been having random BSOD with different Bug Strings for the past two months and I was wondering if you guys could help me out.
My system is as follows:
Ryzen 3600
Asus TUF B450-PRO GAMING
2x 8GB HyperX 3200C16D4
Sapphire RX 580 Nitro+
NVME MP510 240GB for the OS
Toshiba HDWD120 2TB
Corsair 650W PSU
Windows 10 Pro 1909 Build 18363.900
Initially I thought it was a memory issue since I had a pair of g-skill 3000mhz that was not certified by ASUS so I switched to the HyperX ones but the issue continued.
Things I've tried so far:
  • Updated Bios
  • Clean install + drivers from ASUS
  • Disabled XMP profiling
  • Tried both XMP profiles, 3000mhz and 3200mhz
  • Reassembled PC from scratch
  • Clean install + IOBIT driver booster drivers
  • Default BIOS optimized settings
None of the above have kept the it away from a BSOD for more than a few days. But what is really weird is the fact that I've got over 40 BSOD's that I've gotten, none happened while I was gaming. Always happened while working/browsing and while the PC was idle.
I've been thinking about replacing the Motherboard for a B550 when they come out but I'd really rather not since I'm from brazil and electronics are twice as expensive over here.
Here is the last two minidump BSOD from bluescreenview that I've gotten:
062220-8656-01.dmp 6/22/2020 8:20:17 PM DRIVER_IRQL_NOT_LESS_OR_EQUAL 0x000000d1 00001f80008400aa 00000000000000ff 0000000000000000 00001f80008400aa ntoskrnl.exe ntoskrnl.exe+1c23a0 NT Kernel & System Microsoft® Windows® Operating System Microsoft Corporation 10.0.18362.900 (WinBuild.160101.0800) x64 ntoskrnl.exe+1c23a0
062220-8953-01.dmp 6/22/2020 3:56:03 AM UNEXPECTED_KERNEL_MODE_TRAP 0x0000007f 0000000000000008 ffffaa00218b01b0 0000000000000000 fffff804129d3e94 ntoskrnl.exe ntoskrnl.exe+1c23a0 NT Kernel & System Microsoft® Windows® Operating System Microsoft Corporation 10.0.18362.900 (WinBuild.160101.0800) x64 ntoskrnl.exe+1c23a0
but it is an unkindlyfix as its not telling me a great deal :)
top one looks my gpu driver error but you seem to have a new AMD GPU driver.
AMD say this about this sata drivers - https://www.amd.com/en/support/kb/faq/pa-250
you seem to have them
Mar 19 2015amd_sata.sysAMD SATA Controller AHCI Device driver http://support.amd.com/
Possibly update synapse
Maybe test ram with memtest - I read you on 2nd set of ram now. Just to be sure. Its possible errors are drivers still
Try running memtest86 on each of your ram sticks, one stick at a time, up to 4 passes. Only error count you want is 0, any higher could be cause of the BSOD. Remove/replace ram sticks with errors...
Can you go to c windows/minidump
copy the dump files to documents
upload the copies from documents to a file sharing web site, and share the link in your thread so we can help fix the problem
Using driver Booster to update drivers can lead to it installing the wrong drivers. You shouldn't use those programs
Hi, I ran the dump files through the debugger and got the following information: https://unkindlyfix.htmlpasta.com/ Ignore the address name, they are randomly assigned and I have no control over them.
File information:062220-8953-01.dmp (Jun 22 2020 - 02:56:03)
Bugcheck:UNEXPECTED_KERNEL_MODE_TRAP (7F)
Probably caused by:memory_corruption (Process: LeagueClientUxRender.exe)
Uptime:1 Day(s), 9 Hour(s), 00 Min(s), and 28 Sec(s)
File information:062220-8656-01.dmp (Jun 22 2020 - 19:20:17)
Bugcheck:DRIVER_IRQL_NOT_LESS_OR_EQUAL (D1)
Probably caused by:memory_corruption (Process: System)
Uptime:0 Day(s), 5 Hour(s), 59 Min(s), and 41 Sec(s)
Possible Motherboard page: https://www.asus.com/us/Motherboards/TUF-B450-PRO-GAMING/
You have the latest BIOS already installed, version 2007.
This information can be used by others to help you. Someone else will post with more information. Please wait for additional answers. Good luck.
Try running memtest86 on each of your ram sticks, one stick at a time, up to 4 passes. Only error count you want is 0, any higher could be cause of the BSOD. Remove/replace ram sticks with errors. Memtest is created as a bootable USB so that you don’t need windows to run it
