G
Guest
Guest
Please help me 🙁 i got BSOD on my new laptop 🙁
i has follow some Sugestion form other forum.
to use memory diagnostic but no detect problem, and i has update vga from amd website
From Whocrashed
Crash dump directory: C:\Windows\Minidump
Crash dumps are enabled on your computer.
On Fri 5/12/2017 7:42:46 PM your computer crashed
crash dump file: C:\Windows\Minidump\051217-25765-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x14CC20)
Bugcheck code: 0xA (0x7FFBBB435FF8, 0x2, 0x0, 0xFFFFF80176C98324)
Error: IRQL_NOT_LESS_OR_EQUAL
file path: C:\Windows\system32\ntoskrnl.exe
product: Microsoft® Windows® Operating System
company: Microsoft Corporation
description: NT Kernel & System
Bug check description: This indicates that Microsoft Windows or a kernel-mode driver accessed paged memory at DISPATCH_LEVEL or above.
This appears to be a typical software driver bug and is not likely to be caused by a hardware problem.
The crash took place in the Windows kernel. Possibly this problem is caused by another driver that cannot be identified at this time.
crash dump file: C:\Windows\memory.dmp
This was probably caused by the following module: ntkrnlmp.exe (nt!KeBugCheckEx+0x0)
What happend ?
From Whocrashed
What happend ?
