Solution B B bajgur May 18, 2018 both dump file refer to memory corruption, from process of google update and search filter host. so, you might want to check your RAM again. use memtest. edit: memtest needs to be run for at least 8 complete passes for conclusive results.
B bajgur Reputable Nov 29, 2016 280 1 4,865 May 16, 2018 #2 check your ram with memtest Upvote 0 Downvote
E edlp456 Reputable Feb 14, 2016 25 0 4,540 May 16, 2018 #3 bajgur : check your ram with memtest Already did. It's fine apparently. Upvote 0 Downvote
B bajgur Reputable Nov 29, 2016 280 1 4,865 May 16, 2018 #4 upload the dump file then, so we all can look what exactly happened... Upvote 0 Downvote
E edlp456 Reputable Feb 14, 2016 25 0 4,540 May 17, 2018 #5 bajgur : upload the dump file then, so we all can look what exactly happened... How can I do this here? Is there a site I can upload it to? Upvote 0 Downvote
B bajgur Reputable Nov 29, 2016 280 1 4,865 May 17, 2018 #6 edlp456 : bajgur : upload the dump file then, so we all can look what exactly happened... How can I do this here? Is there a site I can upload it to? use google drive/box/dropbox/onedrive/etc... Upvote 0 Downvote
E edlp456 Reputable Feb 14, 2016 25 0 4,540 May 17, 2018 #7 bajgur : edlp456 : bajgur : upload the dump file then, so we all can look what exactly happened... How can I do this here? Is there a site I can upload it to? use google drive/box/dropbox/onedrive/etc... https://www120.zippyshare.com/v/g5RdKSaw/file.html Upvote 0 Downvote
B bajgur Reputable Nov 29, 2016 280 1 4,865 May 18, 2018 Solution #8 both dump file refer to memory corruption, from process of google update and search filter host. so, you might want to check your RAM again. use memtest. edit: memtest needs to be run for at least 8 complete passes for conclusive results. Upvote 0 Downvote Solution
E edlp456 Reputable Feb 14, 2016 25 0 4,540 May 18, 2018 #9 bajgur : both dump file refer to memory corruption, from process of google update and search filter host. so, you might want to check your RAM again. use memtest. edit: memtest needs to be run for at least 8 complete passes for conclusive results. I remember reading about another third party program that analyzes the RAM. I think it was MemTest86. Should I try that one or is it inaccurate? Upvote 0 Downvote
B bajgur Reputable Nov 29, 2016 280 1 4,865 May 19, 2018 #10 edlp456 : bajgur : both dump file refer to memory corruption, from process of google update and search filter host. so, you might want to check your RAM again. use memtest. edit: memtest needs to be run for at least 8 complete passes for conclusive results. I remember reading about another third party program that analyzes the RAM. I think it was MemTest86. Should I try that one or is it inaccurate? yes, that what i was referring to. sorry didnt actually remember it. run the test for at least 8 complete passes. Upvote 0 Downvote
