Question BSOD - ntoskrnl.exe - A possible fix related to OneDrive ...
Nov 25, 2021
16
Was getting BSOD with random errors on Win 10 Pro (64) almost every day for 2 years now. Would reinstall, upgraded to Win 11, nothing helped. The errors were random... with (sometimes) file corruption after SFC or DISM scans...
I checked SSD's for errors, I checked RAM... nothing! Ever!
The culprit was always some driver connected with the "ntoskrnl.exe", which does not tell much...
I use Morrowind MGE, which requires Visual C++ Redist. I blamed on that... did not seem to solve it after uninstalling everything related to it.
Now I tied this fix (Disable Microsoft OneDrive) from here: https://howtofixwindows.com/fix-pfn-list-corrupt-bsod-windows-10/
10 days without BSOD, too early to tell... but could this be it?
Did anybody have anything like that???
My specs:
i9 9900K
Asus Z390 Hero XI WIFI
GSkill 4100 (32GB DDR4)
Samsung 970 Pro, 512GB
GeForce STRIX 1070
PSU - Seasonic Prime 850 Platinum
... I do have a mild overclock.
DUMPS:
https://usaupload.com/shared/5eewl8...l9tpryje8dkna2xu_mid8xwq0gmes50xzy7jbyvr082v8
Dump File : 111421-4859-01.dmp
Crash Time : 11/14/2021 11:42:56 PM
Bug Check String : MEMORY_MANAGEMENT
Bug Check Code : 0x0000001a
Parameter 1 : 0000000000000403 Parameter 2 : fffff72bbc0769b8
Parameter 3 : 860000071a4ae847 Parameter 4 : fffff72bbc0761b8
Caused By Driver : ntoskrnl.exe
Caused By Address : ntoskrnl.exe+415590
File Description :
Product Name :
Company :
File Version :
Processor : x64
Crash Address : ntoskrnl.exe+415590
Stack Address 1 :
Stack Address 2 :
Stack Address 3 :
Computer Name :
Full Path : C:\WINDOWS\Minidump\111421-4859-01.dmp
Processors Count : 16
Major Version : 15
Minor Version : 22000
Dump File Size : 2,943,532
Dump File Time : 11/14/2021 11:43:41 PM
Dump File : 111321-4656-01.dmp
Crash Time : 11/13/2021 11:08:14 PM
Bug Check String : DRIVER_OVERRAN_STACK_BUFFER
Bug Check Code : 0x000000f7
Parameter 1 : ffffa5861804af60 Parameter 2 : 000015affea64f90
Parameter 3 : ffffea500159b06f Parameter 4 : 0000000000000000
File Description :
Product Name :
Company :
File Version :
Processor : x64
Stack Address 1 :
Stack Address 2 :
Stack Address 3 :
Computer Name :
Full Path : C:\WINDOWS\Minidump\111321-4656-01.dmp
Major Version : 15
Dump File Size : 3,144,204
Dump File Time : 11/13/2021 11:08:58 PM
Dump File : 111221-4968-01.dmp
Crash Time : 11/12/2021 12:02:01 AM
Parameter 1 : 00004e023e1da3e0 Parameter 2 : 00004df7bedfe52b
Parameter 3 : ffffb20841201ad4 Parameter 4 : 0000000000000000
File Description :
Product Name :
Company :
File Version :
Processor : x64
Stack Address 1 :
Stack Address 2 :
Stack Address 3 :
Computer Name :
Full Path : C:\WINDOWS\Minidump\111221-4968-01.dmp
Major Version : 15
Dump File Size : 2,478,628
Dump File Time : 11/12/2021 12:03:33 AM
Dump File : 111121-4968-01.dmp
Crash Time : 11/11/2021 8:54:56 PM
Bug Check String : PFN_LIST_CORRUPT
Bug Check Code : 0x0000004e
Parameter 1 : 0000000000000006 Parameter 2 : 000000000011b5f5
Parameter 3 : ffffa3e1176eb126 Parameter 4 : 0000000000000000
File Description :
Product Name :
Company :
File Version :
Processor : x64
Stack Address 1 :
Stack Address 2 :
Stack Address 3 :
Computer Name :
Full Path : C:\WINDOWS\Minidump\111121-4968-01.dmp
Major Version : 15
Dump File Size : 3,091,884
Dump File Time : 11/11/2021 8:55:40 PM
Dump File : 110921-5312-01.dmp
Crash Time : 11/9/2021 3:56:39 AM
Parameter 1 : 0000010aa904f5e0 Parameter 2 : 0000c9b97cb6196f
Parameter 3 : ffff36468349e690 Parameter 4 : 0000000000000000
File Description :
Product Name :
Company :
File Version :
Processor : x64
Stack Address 1 :
Stack Address 2 :
Stack Address 3 :
Computer Name :
Full Path : C:\WINDOWS\Minidump\110921-5312-01.dmp
Major Version : 15
Dump File Size : 3,173,244
Dump File Time : 11/9/2021 3:57:23 AM
if you have fast startup on, the pc isn't off when you shut it down, its in a hybrid hibernate mode. Its why uptime is not = to how long PC on today. With fast start up off, PC is actually off on shut down = https://www.tenforums.com/tutorials/4189-turn-off-fast-startup-windows-10-a.html
Hah... I will turn them off. I had played with this in the past on Win 10, didn't seem to help, but couldn't hurt if I turn it off.
i have a injured hand and can't really type a lot right now. I fell over today, sore wrist. bruise near left eye. bruised legs and sore ribs
Geez, hope you get well soon. Take care man, I appreciate your help very much, but you don't need to do it when you feel like that. Thanks a lot.
dump shows mostly CPU actions, no indication what might be cause. Victim was the client that the user environment runs in. if it crashes windows has no choice but to crash as well.
...Sounds worrying... /: I use a Graphite thermal pad instead of a paste on CPU, but temps seem to be fine... so doubt it has anything to do with that.
cpu doing everything is normal, its not a problem, it just meant I couldn't see any driver names or any interaction with ram or storage.
Fast startup can trip over old drivers that aren't designed to work with it, so turning it off can help.
Fast startup in bios is different function to that in windows.
Fast startup in bios just performs all the tasks at once, instead of sequentially, at boot to give windows control as fast as possible
Fast startup in windows changes how shutdown works/power management.
