Hi Guys.
I just finished my first build, but am now having issue with the BSOD. Last night it would crash within 5 seconds of starting but gave no good details in minidump. I removed a ram slot and was able to boot long enough to upload the drivers. Once I installed the ram again, I ran memtest and got 100% passes so I thought maybe it was just a hiccup.
I booted it up today and tested out starcraft II and after maybe 30 minutes I got the BSOD again. Now I am getting the following from minidump. Any suggestions?
I have an intel core i7 8700k, Asus Prime z-370 p, and 16 gb (2x8) G.Skill Trident ram. The video card still hasn't arrived from Amazon, so all issues were using integrated graphics, and I'm running Windows 10.
WHEA_UNCORRECTABLE_ERROR (124)
A fatal hardware error has occurred. Parameter 1 identifies the type of error
source that reported the error. Parameter 2 holds the address of the
WHEA_ERROR_RECORD structure that describes the error conditon.
Arguments:
Arg1: 0000000000000000, Machine Check Exception
Arg2: ffff960a69140028, Address of the WHEA_ERROR_RECORD structure.
Arg3: 00000000be000000, High order 32-bits of the MCi_STATUS value.
Arg4: 0000000000800400, Low order 32-bits of the MCi_STATUS value.
Debugging Details:
TRIAGER: Could not open triage file : e:\dump_analysis\program\triage\modclass.ini, error 2
BUGCHECK_STR: 0x124_GenuineIntel
CUSTOMER_CRASH_COUNT: 1
DEFAULT_BUCKET_ID: WIN8_DRIVER_FAULT
CURRENT_IRQL: f
STACK_TEXT:
ffffa681`fa484ce8 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KeBugCheckEx
STACK_COMMAND: kb
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: GenuineIntel
IMAGE_NAME: GenuineIntel
DEBUG_FLR_IMAGE_TIMESTAMP: 0
FAILURE_BUCKET_ID: X64_0x124_GenuineIntel_PROCESSOR_MAE
Followup: MachineOwner
Arguments:
Debugging Details:
CURRENT_IRQL: f
STACK_TEXT:
STACK_COMMAND: kb
