[BSOD]'s constantly on first start of the day. Variety of BSODs and clean installed 5 times now with same problem.
mrpenguiny
Commendable
Oct 30, 2017
Hello,
Windows 10 Pro
Asrock Z270 Extreme4 Motherboard
Geforce 1080 Founders Edition
i7-7700k 4.20
2x 8gb Corsair Vengeance LPX DDR4 3000MHz
I built my own computer a long time ago back in 2011. About a month ago I bought basically a whole new computer. New Motherboard, RAM, Graphics card, and Processor. The only thing I kept was a 500gb SSD Samsung 850 EVO and the tower. I tried doing a transfer without wiping the SSD. It resulted in many errors and ended up wiping the SSD and doing a clean install from a USB. After the clean install I have been getting BSODs non stop only on the initial start of the day. If I restarted my computer right now as I am typing this, it wouldn't BSOD.
I have done extensive research on how to fix BSODs and the best solution I have found is clean installing. The same BSODs come back everytime I do so. I don't know what to do now. I've done 2 different memory tests (Microsofts built in version and the 3rd party memtest86) both had no errors but just incase I re-inserted the RAM sticks, I've reinstalled my nvidia graphic card drivers with also cleaning out the earlier versions installed. I've done multiple sfc /scannow's and chkdsk /f c:'s. No errors or issues. The only thing I haven't successfully done is a verifier check because everytime I followed through the instructions I have not been able to get into safemode after I Bluescreen out with verifier finding an error. It would get to windows recovery but wouldn't give me an option to start in safemode, even with loading into the usb repair tool. I am hoping someone can help.
Keep in mind these are all new parts bought of amazon not from 3rd party retailers, and when I clean installed for the 5th time I have been restarting the computer after every driver install and I noticed the BSODs start after the Nvidia Drivers were installed. I have uninstalled and reinstalled them and the problem still was there so I don't think it was them. I have absolutely no idea what to do now. The computer starts normaly after the parts are warmed up it seems. I don't understand it.
The BSODs are:
BSOD: BAD_POOL_HEADER
Time: 10/30/2017 - 10:03
Bug Check Code: 0x00000019
Caused by driver: ntoskrnl.exe
BSOD: CRITICAL_PROCESS_DIED
Time: 10/30/2017 - 11:36
Bug Check Code: 0x000000ef
BSOD: KMODE_EXCEPTION_NOT_HANDLED
Time: 10/30/2017 - 11:32
Bug Check Code: 0x0000001e
Caused by driver: ntoskrnl.exe, iaStorAV.sys, FLTMGR.SYS
BSOD: MEMORY_MANAGEMENT
Time: 10/30/2017 - 11:33
Bug Check Code: 0x0000001a
BSOD: SYSTEM_SERVICE_EXCEPTION
Time: 10/30/2017 - 11:34
Bug Check Code: 0x0000003b
NTOSKRNL = windows kernel. It handles all driver requests, power management, and memory management. It sits between Hardware and Applications. It got blamed but its not the cause
Can you follow option one here
and then do this step below: Small memory dumps - Have Windows Create a Small Memory Dump (Minidump) on BSOD
that creates a file in c windows/minidump
copy that file to documents
upload the copy from documents to a cloud server and share the link here and someone with right software to read them will help you fix it :)
Did you try to download the App Shop from here: https://www.asrock.com/MB/Intel/Z270%20Extreme4/index.asp#osW1064
it will check drivers and make sure you have the latest for motherboard.
