Basically i am with BT in the UK and have a BTHomeHub 3 and port forwarding is a nightmare. Settings up i static IP is easy and hard. I know how to but when i use my PC and launch CMD and do ipconfig/all i get the IP, DNS server etc but in the bthub manager it has a completely different set of information as well as that i can't port forward because it keeps saying that my port is conflicting with another port even though there's no other ports active, also people say to disable UPNP but i have and restarted my router. I live in a family home so i can't restart the router because of that and other reasons.
Error:
The game or application you’ve selected conflicts with an application () you’ve already assigned to another device.
Please remove the other application or select the same device.
The "with an application () you’ve already" part the () are meant the hold a game or application that's conflicting but its blank
Basically what i am looking for is:
An answer on which information i should use, what the CMD says or what the router says,
What is the problem with port forwarding on my router?
Thanks to all who reply.
Error:
