http://I have just bought a refurbished LG 65inch OLED B7 and upon inspection noticed clusters of what appear to be small bubbles a few mm in diameter on the panel intermittently spaced across a horizontal line. At first I thought it was muck but it won't wipe off and there doesn't seem to be a protective film in the panel to peel off. I don't know if there is a way to post photographs on here as I'm probably not describing it very well.
My question is does anybody know what may have caused it, and is it something to worry about if it doesn't affect the picture quality at the moment, I.e. is it likely to get worse.
Cheers in advance
Edit: cant figure out how to embed a pic so heres a link:
http://
Cheers in advance
http://
