Budget PC Parts
Mar 13, 2018
32
So what I have done was gathered all the pc parts that I think I would need.(I'm on a tight budget) I just don't know if this is all compatible..... so can anyone verify for me please.
PC parts:
NZXT S340 Mid Tower Computer Case, White (CA-S340W-W1)
MSI Gaming Radeon RX 560 128-bit 4GB GDRR5 DirectX 12 VR Ready CFX Graphcis Card (RX
560 AERO ITX 4G OC)
Intel Core i3-8100 Desktop Processor 4 Cores 3.6GHz LGA1151 300 Series 65W BX80684i38100
Ballistix Sport LT 8GB Kit (4GBx2) DDR4 2400 MT/s (PC4-19200) DIMM 288-Pin -
BLS2K4G4D240FSB (Gray)
EVGA 450 BT, 80+ Bronze 450W, 3 Year Warranty, Power Supply 100-BT-0450-K1
WD Blue 1TB SATA 6 Gb/s 7200 RPM 64MB Cache 3.5 Inch Desktop Hard Drive (WD10EZEX)
MSI ATX Motherboard Motherboards Z370-A PRO
Yes, it’s fine.
If you plan to upgrade to your cpu / gpu later on, it’s wroth getting a 500w/600w psu,
If you are just using the system as it is, you can wait for 2week and get a B360 Mobo instead of z370, it should be a bit cheaper and you won’t lose any feature, based on your hardware choices.
